I really enjoy the 963s we use to load clay with here, company also has rubber tire Deeres where they handle the more loose materials better/faster but hard to beat a old track machine for breaking out compacted piles.
those trackpads are for steel mill application, there would also be a full fire extinguisher system and possibly a different hydraulic fluid, there was a water based hydraulic fluid used in a steel rolling mill I used to work at it looked like milk, that was in the late 1970's. I used to drive a Komatsu D41S track shovel, which was lifted into a 30' deep pit beneath an 150 tonne capacity electric arc furnace, once the top was taken off the slag pile, the slag would stick on to the tracks. That was a beautiful machine with an 80hp 6 cylinder engine, there was a lot of powdered lime in the bottom of the pit and I suppose it got sucked into the engine because after 4 hours running it needed one gallon of oil in the engine, but it always started first try hot or cold and ran very smoothly.Surprised there isn't fire nozzles all over it. Curious if the track pads are rubber and if a machine like that would have special high temp. hoses and such? Imagine a hyd. leak.
Yes Dave, the machine I operated got on fire a few times, although not while I was driving it, and not seriously, there would be another operative "fire watching" with a 2" water hose, the regular driver, who had been doing the job for 30 years, only used to wear a paper dust mask, I used to wear a siebe gorman mask with double filters and keep the cab door closed and blower on full blast. The overhead crane would lower a skip down on to the top of the slag pile, which would be 18' to 20' high, through a hole with a steel plate over it on the shop floor level. Before they removed the plate, I would backblade the slag pile to reduce its height, this would expose the red hot slag who's consistency would stick to the tracks, I would then try and dig a small hole for the skip to sit in, this would reduce the steep angle required to drive up the pile to load the skip, which made driving the machine more comfortable. When the red hot slag was backbladed I was careful to not sit the machine over the hot material while waiting for skip to be tipped, ( I always checked the machine for oil leaks before it was lifted down the pit). the only light was a 500 watt halogen light hung down above the skip, once a bucket full was tipped it was like being in outer space, everything went black and all you could see was the windscreen wipers. If you moved the machine with such low visibility and ran over any obstruction,( there was scrap down there which had missed the furnace during charging), you were so disorientated that it felt like the machine would tip over, so I learned to wait a few seconds until dust cleared and the light showed through, happy days!!Still has to be a very dangerous application. Have seem pics. of large wheel loaders like Clark 475's burnt up removing slag.
One look in the trade papers and I see why. [/QUOTE said:Skyking are you talking about the high prices people are asking for some of these old machines.
beautiful machines you mentioned, they look like fossil finds, dinosaurs from the museum of science and industrial technology, were the forerunners of our current modern machines. what leap has technology made in recent years.
No, talking about 4 total machines for sale in my state. They are very few out here. They seem to be about 6% of available loaders on the market.Skyking are you talking about the high prices people are asking for some of these old machines.
Dave, the melting shop I worked at was one of the first in the UK to have electric arc furnaces installed, and had a system of pits and tunnels beneath it, most other melting shops slagged out onto shop floor level, so the furnace was in an elevated position, IE on first floor level, the track loader slagging out would have access to drive to the outside where any fire could be dealt with in comparative safety. The only way to extract the loader I drove was by overhead electric crane, so early intervention with a fire hose was very important. We had hours of waiting to go down the pit because we had to have an atmosphere test to check the oxygen levels, as they teemed the molten metal from the ladles through a shield supplied with argon gas to prevent hydrogen embrittlement in the steel ( you will know about that being a welder - low hydrogen welding rods) and argon is an asphixiant and heavier than air, so it was important to check if argon had settled in the pit. The company I was working for was a small company and the boss did'nt like spending money so no automatic fire surpression system on their machine! The modern machines used on slagging duties, as in the pictures Trombeur has kindly posted would have automaticSounds like a job you absolutely have to do right. Do you know if most most steel mills have someone at the ready with a fire hose?
Thanks for sharing that Willis. Running a track loader in a steel mill application is someone you don't run into every day. Fascinating and terrifying all at the same time.
As far as track loader manufacturer's go:
Komatsu - made a front and rear engine Cat copy
JCB - made a rear engine machine
Hanomag - front engine machine
Massey Ferguson - front engine machine
Dresser - front engine
International - front engine
Now most of the above list is the same engineering/design when each company was bought or absorbed through merger.
Probably one of the rarest track loaders. JCB rear engine. The machine was really ahead of it's time with a 1971 release date.
fire systems and heat resistant cab glass. Most steel mill track loaders have a wire towing rope for recovery should they break down, some brave soul would have to connect the rope to the recovery vehicle! Sadly the melting facility closed in 2003, sadly partly because it always made money, and it made engineering steels which were supplied to aircraft, oil, nuclear and automotive industries.
