jackleg
The Case has sat for a while and now won't start.
Cranks over good. No smoke or indication of even trying to fire. Sounds "normal" when cranking.
I've had a heater on it for a day now. Checked the inlet screen to the pump and it's clean with good fuel flowing from the filters to the pump. I loosened one of the lines to an injector and no fuel when cranking. Took the little cover off the side of the pump and fuel flows out with no pieces/parts. Are the internals of the pump supposed to rotate with the engine? They don't appear to be. I'm thinking the pump is bad, anything else I should check?
Thanks.
Thanks.
