bflobil
Just started running a TS-14 scraper that I bought and I am totally new to the scraper business. Its and older machine that has a DT466 retrofitted up front and the 4-71 in the back. I can turn the steering wheel about a half turn each way before any action and then it seems to jump that way. It is a nightmare to travel down the road with it jerking back and forth. There is some "slop" in a bolt under the cab where the steering is converted to the in-line plunger(forgive my ignorance in not knowing the proper terms) Any guidance from you all on what to look at for that? I assume I can eliminate some of the slop but I'm not sure that will take out the jerkyness in the steering.
