Will do, thank you muchFirst check fuses, then if your fuses are good check the voltage by back probing the wires at the switch. Check the voltage while trying to extend and retract. If you find voltage on both wires you probably dont have a ground. The unplug your switch from the wires and check for continuity while activating the switch.
