Td8e transmission problem
Mowit
Kosse Texas, United States
Td8e that has been sitting in a barn for 3-5 years and recently got it running. Runs good steers good and goes thru all the gears smooth. But the problem is after driving for a short distance the dozer starts slowing down, the drive shaft also slows down. Filter and fluid has been changed and screen cleaned with no debris in it. Any suggestions what to check next ?
R.D.G013
sunshine coast qld australia
Heavy equipment operator/foreman for about 48yrs o
If the driveshaft slows down, does the engine revs slow down as well or is it at full revs but under load because of a transmission problem. Sounds more like a fuel supply problem to me if the engine revs drop as well.
