I’m looking at possibility purchasing a TD15E. I’ve seen older post regarding parts availability. Is there anywhere to still get some parts. Also if the final drive is overfilled (I assume leaking from trans) is that a huge issue? Is there a way to check pivot shaft since that seems to be a common issue? Any advise is appreciated Dozer has rebuilt cylinders. New undercarriage. 4800hrs
