Hi there, TD15c's can be temperamental in their transmissions and some times take a bit to understand but in saying that they are a great tractor. They can suffer from internal leakage in their pistons but if they do they generally slip after changing gear and this will normally affect more than one gear. These transmissions have manifold with plugs in them so that you can check the pressure that is going through each shaft to suppy the pistons. From memory there is one on the front of the trans and one on the back. Without looking at a book I think the rear one is on the P.T.O. shaft (winch drive) which is in line with the input from the torque convertor. The front one is off to one side and will unbolt without removing the trans, when unbolted the end of the shaft is exposed along with 4 piston type seal rings. As I said you can check the pressures here, If you have good pressure here chances are you need to dig deeper, if your pressure is not good here try looking at your control valve. Hopefully this is of some help to you, when the transmission are right they are good and give good service. As I said a great tractor, did a lot of hours on my one and loved it, Good luck.
