In it's day, TCH was the premium oil for both AG and Industrial transmissions in Case equipment, without having specific numbers I know that Case recommended a type A ATF fluid as a satisfactory replacement in most applications. Now TCH has been replaced by Hy Tran Ultra for all applications except the hydraulic clutch crawler transmissions in use before the hydrostats. While I am not as anti Wal Mart as some, as my wife has worked for one for 16 years I can say after 48 years in the same shop that some oils have ingredients that are not kind to the V cup seals used in Case's glands and will cause some of the older piston packiings to swell to the point that we had to winch some apart with the winch on a rollback to dissasemble for a rebuild. They were so tight that when worked hydraulically they squealed like a pig when activated. I would use HTU if I were you as it is a proven product and the price difference between that and a bargain basement oil will not rebuild one cylinder at todays parts and labor prices. Just my opinion, but not without applying facts and personal observation and hands on experience into the decision to recommend genuine Case oil. Mel.
