TB260 starts, won't operate.
csthompson12
usa
Hi, I have a '15 Takeuchi TB260. It starts up, but that is it. Does not operate, no controls work, no throttle, no gauges, hour meter etc...
I have checked wiring, fuses. I am pretty sure my problem is the module/controller box that is located under the seat area. The part looks to be 1200$. Wanted to make sure it was the problem.
Has anyone had a similar problem, and had a module/controller go bad?
csthompson12
usa
Fusible links are good. I am still thinking the controller is bad. I did find the service manual and flip through it. No mention of how to test/condemn the controller that I could see.
I'm not sure if I should take and chance at it for a $1200 part and try it myself, or take it to the dealer at this point. I'm sure they could probably tell if that was the problem pretty fast.tak.png
csthompson12
usa
Got it back from the dealer, it was a faulty controller as circled above. Seems unusual for this part to fail. The part was 1800$.
Rob Beers
Mcdowell, Virginia
I have the exact same problem. I think I ruined it trying to jump start it without a big enough jumper cable. At least the problem started right after that.
BigAl'sDirtWorks
kentucky
Thanks for the follow up to let us know what the answer was. You know it's gonna hurt any time you go to the dealer, but glad they were able to get you up and running.
csthompson12
usa
Hmm mine has dead battery now and then. Wonder if those modules don’t like the battery being jumped. My module under the seat went bad. They have a couple led’s on them that blink when the key is turned on. On mine they did not blink so that was one clue.
