I have a 30ft tandem dual flatbed that i use pretty hard and pull very heavy with it for severral years i own and used it. I flat out love this trailer and unfortanaly I have worn the suspunsion system pretty dang good so its in need to replace the entire suspunsion system out, it currently have 42 1/4" axle spacing, 4 inch hangers 2 1/2" slipper springs equalizer is 18 3/8" front to rear hanger is 70" front hanger to equalizer center is 35" same for the back. I can not find me a equalizer of the same size unless i switch to 3" springs. I been thinking hard as I pull it and heavy as i load it maybe i should add a 3rd axle on it behind the current tandem and can put more weight on back of trailer not have it buck or make truck to light. I constantly load it down up to 40,000lbs Gross weight and tare around 18,000lbs. Currenty have no issue with tires, stoping etc just thought it would be nice for extra braking power and spread the weight out a little.
was wondering if anyone has messed with a triple axle duals gooseneck flatbed before and their experinces. I have seen several of them and the guy says they pull really smooth
