Was using the TL230 yesterday, seemed to be running normally, shut it down to cut up a log. Went to restart it, get the normal light show on the indicator panel but it won’t crank. Once the light show is over, the oil pressure light blinks and the alarm sounds in sync with the oil pressure light. Things I have checked:
- Battery voltage 12.6V
- Voltage from battery negative post to frame less than 0.05V
- All fuses check ok, removed and cleaned contacts, reinstalled
- Voltage on coil of start relay when cranking - 0.0V (relay hasn’t failed)
- Start relay is driven by the safety relay, which has 3 inputs:
- Keyed 12V is present
- A pin with a white / black wire is at 11.0V when key is in start position
- A pin with a blue wire remains at zero V, suspect this is the alternator tachometer output (blue wire on alternator)
Wiring diagram shows a second start relay that is controlled by the computer, don’t know where this relay is physically, thinking that is the source of the white / black wire. This relay switches battery voltage, don’t know why it’s measuring 11.0V. Alarm stops sounding when I remove the safety relay. I am preoccupied by the oil pressure light, could we have a failed oil pressure switch / broken wire? Any guidance on where the pressure switch is physically located (Kubota 4cy diesel)? Any other suggestions?
Thanks in advance!
Thanks in advance!
