heymccall
My gut says alternator for the lamp flashing.
Or one of the little wires is broken.
Ok thanks!You could do that. But you'll lose the low oil and low coolant shutdown feature.
I'd simply cut the red wire on the solenoid, leave the chassis side open, and connect the red of the solenoid to a key switch source.
You'll still go on and off via key, and still get warning alarms, just no emergency shutdowns.
Do you get any other lights flashing when it dies? Did you verify that it's not your coolant level sensor that kills the machine? I believe you can just ground it to bypass to test when machine dies. There's other threads on here about this sensor. Fairly common issue.
If there is no way to kill the machine electronically if the fuel cutoff solenoid is not in, could it possibly be the lift pump?
I was thinking about plumbing in a pressure gauge on the out going side of the lift pump to determine the pressure that the lift pump is putting out. Does anyone know what psi the lift pump is supposed to put out?
