I can't get my lower pin to take grease. So my solution is to pull them out, clean it up and replace the pins if warranted (I don't think that's the case).
I'm stumped right out of the gates. There's a bolt through the end of the pin with two nuts on it. Not sure if this is factory. I can get the nuts off with no problem, but that bolt is not budging. It looks like the bolt is all thread - but surely it's not. I can't budge the bolt with a socket, or with a light beating (heat included). Anyone dealt with this? How are these bolts made? Threaded through tube that holds the pin?
Thanks,
Thanks,
