T200 blowing fuel solenoid fuse
willie59
Knoxville TN
Service Manager
Since you have removed the spring and levers removed as you stated in post #16, it will run whenever you crank the engine regardless if you have harness connected or not. The only thing it won't do is shut down engine, you have to do that manually. ;)
T200
MASS
Update.... New solenoid came in today and all is well. Total cost of $93 by purchasing one on amazon.com as opposed to the $373 price tag from bobcat. Thanks again for all of your help.
DieselFuel
Toronto
Willie....is there a photo you can post of the manual shut down lever at the injection pump say for the kubota engine?
thanks in advanced
crewchief888
NWI
manual shutdown lever is located directly below the throttle lever .
throttle has linkage connected to it, the shut down lever doesnt.
kubota engine wasnt introduced until after the t200 went out of production. very early SN S / T 250's had the duetz engine. they werent in production long before the v3300 kubota replaced them.
:drinkup
