T190 Right side track problems
Knoxville TN
Service Manager
I'd make it long enough so that I could see the gauge while operating the machine in the cab.
lantraxco
Elsewhen
While checking pump pressures, also keep an eye on that charge pressure, to see if it exhibits the same drop when the pump comes on stroke. If the pump pressures are decent and the charge pressure stays up reasonably well, then the problem is probably elsewhere, perhaps a failed flushing valve. Cheers
lantraxco
Elsewhen
I don't have any specs on your particular unit but usually you only see a 30 to 50 psi drop, which is the flushing valves opening to dump hot oil out of the loop. Hopefully Willie will have the correct answer. :)
Knoxville TN
Service Manager
The charge pressure should hold around 245 to 255 PSI. As lantraxco stated, you might see a slight drop when flushing valves open, but that should be only momentarily at best.
