Ok, so I replaced the head which was fairly easy except for Bobcat's inability to get me the correct parts. After doing so, I went to fire it and though I got it started, it ran really rough. So I thought , no problem, I'll bleed it and all will be good. I bled cylinders 1,3&4 and all acted normal and blasted fuel out when loosened and evened out when tightened, but number 2 cylinder did nothing of the sort. It just stayed the same and almost no fuel blew out. After repeating the procedure a couple of times, I finally removed the nut at the injector while running and nothing was happening. I then removed the line and blew it out, but there was no obstruction. I had earlier found that the hand pump leaked, so I thought that maybe it was draining down and preventing me from properly bleeding the system. Today I replaced the hand pump, changed the filter and tried once again to bleak the system, only to find that number 2 was still starving. That type of problem is really difficult because I can't help but feel that maybe it has something to do with the head replacement, although that really doesn't make sence. Anyone have any ideas?
