we have a t180 that has low oil pressure and has cut itself off. I put a manual pressure gauge on it and pressure starts at 55 drops to 20s after 20 min running around the yard cycling the loader arms and bucket. I changed the oil pump and it takes maybe 5 more minuites for the same senario to repeat it self. I changed the oil pressure sender with another out of another t180 that we have and the problem still is there. Now i have the engine out and the oilpan off and the rods seem tight the cylinder walls good and the inside of the engine is spotless. One other thing about 20 hrs ago the turbo was replaced because there was oil leaking out of it. Any ideas???? im stumped
