Was hoping somebody here has had some experience in rebuilding these transmissions, as too what our issue might be, Everything has gone well on the assembly up to bolting the front torque convertor cover to remaining transmission assembly , once its tightened we can barely turn the torque convertor when installed, the torque convertor bearing seems to be to tight against the hub gear, and also when we measure the bearing its 18mm wide and the bore in the cover is 17mm deep, not sure if thats correct or not, the hub gear thrust washer and hub gear all look to be in correct position according to parts break down
