Swinger or willmar wrangler wheel loaders
Discussion in 'Compact Wheel Loaders' started by fendtman, May 1, 2009.
  1. fendtman
    fendtman Well-Known Member
    Dec 22, 2007
    94
    michiga
    which is the better of the two. know of any good used ones out there for sale.
  2. pigpig
    pigpig Member
    Jul 22, 2009
    5
    The Boss
    Sudbury Ontario
    I own a swinger 160, love it, never tried a wilmar.
  3. pistons
    pistons Member
    Feb 18, 2010
    18
    ohio
    We have an old loader with Dana 60 diff., spider gears stripped twice in 30 years service. not bad I would say. We currently have a Willmar and really like it. I am sure we will invest far more money in the hydraulic system than the old one in 30 years. At least with the swinger you only have one hyd. motor. As with any new machine, dealer and service can be the deal maker.
  4. adam21584
    adam21584 Well-Known Member
    Aug 4, 2009
    54
    minnesota
    Personally I like swingers. I have been around the 2000 and 240. I like them both, With a good operator they are fast and productive. They are some what high maintenance though. Allot of power for a little machine. I prefer the 2000 because of the 2 speed transfer case.
  5. trainmax
    trainmax New Member
    May 10, 2010
    4
    Louisiana
    Where did you get the new gears from? How much did it cost to fix it?
    I am looking at buying one and the rear wheels do not work. I am thinking it may be the same thing. It's a 1979 model.
  6. trainmax
    trainmax New Member
    May 10, 2010
    4
    Louisiana
  7. pistons
    pistons Member
    Feb 18, 2010
    18
    ohio
    We were lucky in that a local repair shop happened to have a whole rear end out of the same loader and we just swapped it out. I would think a good drive-line shop should be able to help you out. I will check and see if I can get some part numbers from the local guy. The last time the gears stripped, if busted the whole inner gear carrier. Another thought. Some one should be able to cut down and make narrower a truck rear end.
  8. trainmax
    trainmax New Member
    May 10, 2010
    4
    Louisiana
    Rear axle
    I was not so lucky the read axle is sheared in half trying to find a new one will let you know how it turns out.
  9. Cuttingedge
    Cuttingedge New Member
    May 24, 2010
    1
    Texas
    What are you going to use it for?
  10. trainmax
    trainmax New Member
    May 10, 2010
    4
    Louisiana
    Axle
    I got it for our Railroad museum to help work on the tracks.
    Will be moving dirt and RR ballast I am also making a set of forks for lifting Railroad ties and stuff.
    I will not be working it every day and I will be the one to run it.
    Is there a truck rear end I can buy and cut down to fit?
    I have every thing here to weld it together.
    Just got the price for a new axle $492.44 plus shipping.
  11. hammerdwn20
    hammerdwn20 Well-Known Member
    Feb 18, 2008
    225
    pipeline
    pa
    we have a swinger at work and it is a powerful machine for its size. It has all 4 tires filled solid and extra counterweight on the back. It will still lift the rear tires. Dumps over the top of our single axle better than our bobcat. We love it!
  12. ogs1022
    ogs1022 New Member
    Nov 4, 2008
    2
    Technical Trainer for Construction OEM
    Wisconsin
    I have had both but recently did a demo with the new Wacker Neuson WL-30 and beats them both hands down. Their parts availability and dealer network is huge.
  13. Sparkie
    Sparkie Well-Known Member
    Aug 4, 2011
    50
    Cyrus MN
    We've got wranglers at work. One for general lifting of whatever and snow removal. And the other spends most of its time loading fertilizer. Our general use one is a 1992 with 5000 hours on it. I'd trust it over the newer 4550 anyday, its just a dinosaur
  14. pitboss
    pitboss New Member
    Jan 8, 2013
    1
    Wisconsin
    They are both good machines but there is a new machine made by Wacker Neuson that I am hearing a lot of good things about.
  15. JGS Parts
    JGS Parts Senior Member
    Apr 17, 2012
    541
    Owner JGS Machinery
    Australia/China
    are these little loaders manufactured in the USA? are they expensive?
  16. lumberjack
    lumberjack Senior Member
    Dec 25, 2011
    1,027
    Columbus, MS
    If you're looking new, I would suggest Gehl, which was built in conjunction with/ Wacker Neuson although it's made in South Dokota. I have the AL540, and my climber has the AL140. I have oodles of video of them.
    The 140 is around $26-27k, $340 is around $34k, the AL540 is around $41k. All these are rough ballparks. The 140 and 540 are fairly accurate, the 340 is approximate. Currently the dealer portal is down for maintenance.
  17. icestationzebra
    icestationzebra Senior Member
    Jun 21, 2009
    320
    I can tell you in no uncertain terms that Wacker Neuson was never involved in the design of the Gehl loaders. ISZ
  18. lumberjack
    Dec 25, 2011
    1,027
    Columbus, MS
    "...n conjunction with/*based their design on* Waker Nueson..."
    Before Gehl/Mustang set up the current deal with Yanmar, their excavators were private label Wacker Neusons. The WL30 and the AL540 are cousins, if not siblings. However, I am not entirely certain of the arrangement regarding the wheel loaders; I would be happy to email the AL product manager for further details.
  19. icestationzebra
    Jun 21, 2009
    320
    You are correct that Gehl was selling rebranded Wacker Neuson products. That effectively ended with the introduction of the AL loaders, otherwise why would they now hook up with Yanmar for excavators? And no they are not cousins or brothers. Lets just say one is a reflection of the other.
    It is very difficult to make money selling rebranded equipment, much less ones that you have to ship all the way from Austria.
    ISZ
  20. lumberjack
    Dec 25, 2011
    1,027
    Columbus, MS
    Haha so they're unrelated twins?
    Their marketing of the excavators is horribly weak... most of their advertising is weak in my opinion.
    Are you near West Bend perhaps? 4001298/42428
    http://www.youtube.com/watch?v=wKI5lOELeb0
