svl 95 14 pin plug
gwhammy
missouri
I've got a tree shear that will rotate if I can hook it up to my machine. I see skid steer solutions has them but they seem a little high. Is this a standard plug they have put on these machines or are they special to equipment. If standard they should be available threw electric supply houses I would think.
gwhammy
missouri
I think I found the answer, they aren't available except threw a few dealers. I guess i won't be a tight ass on this.
heymccall
Western Pennsylvania
It's the duetsch HD30 series. The one below doesn't have the cord grip. And, you have buy the pins separately.
The genuine crimper is over $400. I use a 4 tooth crimper avaliable for around $60.
Tags
Connecticut
If you don't have the electric option it's probably way easier to buy the harness and the plug from Kubota because it will plug right in and you'll be good to go.
heymccall
On my kubotas, I use just a 7 pin trailer plug. After all, mine only have two buttons for electric beyond.
The wiring from the buttons exists in the chassis, just not on the boom (unless you got the full option).
Tags
Connecticut
That's a good idea right there.
gwhammy
missouri
I have the plug, can't cut it as it's traded waiting on a new machine. A trailer plug seems like a good idea with no more pins than they are using.
