A family friends farm that I help at sometimes is in need of a new/new to them skid steer in the 2000-2500lb range. They had a 05 or 06 Gehl 5640 that worked pretty well for them as far as size goes. Mechanically it was a problem child most of it's life and burned while picking up bales a couple days ago so the hunt is on for a replacement. Whatever they get needs to be reliable, used 3-4hrs a day minimum for 365 days a year. It will probably be kept for a minimum of 5,000hrs. (The Gehl had 6850hrs on it and their 753 Bobcat has 7450hrs and is still doing pretty well) Maintenance is so so, could be better so a high maintenance machine won't do.
I've suggest a Case 440 S3, a Bobcat S220 and a Bobcat S250 as machines they should look into. I have not had the chance to run any of the newer M series Bobcat machines or the new series of Case machines. I'd like them to demo a S570/590/630 and SR220 or SR250 as well before buying anything.
They don't need a ton of options. 2 speed, heated cab, and hyd. quick attach would be about all. Anything fancier then that is just asking to get broken by some of the employee's.
Is there any other machines that seem like they would fit the bill?
