Stuck in the middle of the road
chilco
canada vancouver island
jack of all trades master of none
2014, John Deere 310 SKT
CTCU code 522379.05
PARK BRAKE
OUT OF RANGE LOW
I’m searching through a shop manual getting nowhere, desperate for help. Thank you.
chilco
I’m thinking it’s a broken wire on a connector just having a tough time. Locating park brake solenoid help would be appreciated. Thank you
I can't help with the electrical part. If it doesn't get better by shutting it off, disconnect the battery for a minute, then try again. If you just need to move it off the road, does the backhoe and loader still work? put a some scraps of wood under the buckets and wiggle off the road, stabilizers down if it's not flat.
