aighead
Lots of good advice for getting unstuck. Chains did not work for me last time, but they were maybe just too weak.
I'm going to add that it may not be a bad idea to throw on that seatbelt too, if you don't normally wear it. My last time stuck I used the hoe to lift my back wheels out but that had me up in the sky pretty high and it was scary, even with outriggers down close to the ground. My front wheels were also very deep and I felt like I needed to turn the steering wheel a bit as I was able to slide sideways with the hoe side. There was a fair amount of trying to do 3 things at once, so you do a little of each and crawl your way out. What worked for me was lift the back up with the hoe and swing sideways as much as I could, then set the outriggers down, so I didn't slide back into the original hole, repeat that a bunch, hoping the big tires find some purchase, then shoving with the loader bucket while pulling with the hoe.
I'd say as you learn about unsticking it won't be uncommon to spend hours figuring it out. I tend to try for a bit then either just sit and take a break or walk away from the machine for a bit.
Also, learn to get unstuck, even if it takes hours. Looking at your space this won't be the last time it happens. You can also practice by just moving the machine around without driving. You don't have to practice by actually being stuck. Get that feel for swinging the machine around with the hoe and pushing with the loader, but kind of at the same time.
