New to dozers and the forum ☺️ I got a JD 650G. I drove it up the mountain 2 miles and started fluid changes. It seems to run and move fine.
BUT, I found this on the transmission drain plug magnet. It looks like a pin from a needle bearing. Do you think I should pull the transmission and inspect? I’m not even sure how only one of these needles would get loose? If I just ran it, could I cause more expensive carnage?
Appreciate your time and thoughts!
TO650GH767035
4000 hours
Also including pics of the screen. It seems ok and the fluid looked like AT- not in bad shape.
TO650GH767035
4000 hours
