Stop alarm signal in a 310j john deere
ITAMECH61
venezuela
HI i have a 310j backhoe loader when y tur the shift in forward or in reverse in the display panel apear the signol STOP flashing and the mensage is turn the shift to neutal position , ther are not codes actives and other flashing lights,the machine works all right and do the 4 shift fine anyone knows that this signal mean
chine61
mexico
Thanks lantraxco the parking brake is released and the transmision works well
Hi ssme thing just haopen to me. I had a leak on the torque converter, we removed it, repaired it place it again and now the stop alarm buzzes when in fwd or rev. Machine was perfect before the leak repair. What was the issue on your hoe?
Thanks
mg2361
Pennsylvania
Equipment Mechanic
The OP has not been on here since 2016. Not likely you are going to get an answer from him. If your park brake releases the first thing I would check is the park brake pressure switch which is mounted on the top front of the differential. Also post a serial number please.
