Steering Issue
ms0115
Ethridge, TN
Got the pump on. I have forward and reverse hosed up backwards. And have not been able to figure out which ones are crossed nor find a diagram. Does anyone have a hose diagram?
Arny L
canada
According to trackloader parts diagram, the left side control (as sitting in cab), is the rear set of ports, on the pump, closer to eng, one up, one directly below. Right side control is the forward set of ports, one up, one directly below. Once that is correct, then switching hoses at drive motor should give you proper direction,(if the direction is backwards)
Arny L
canada
Did you switch the joystick control hoses back to original, after testing, earlier on in this post.
