DaniZ
OK, so I took pictures and even a video before taking the hoses off to replace the steering cylinders on my 1978 580B or Ck backhoe. Then...phone got destroyed.
Do opossing hoses go to the opposite side cylinders? Like a push pull or are they the same in connection set up; left matches right configuration?
The left side is still connected when I realized no reference to hoses when I finally got the right ball joints pressed out and new unit in. New cylinders looks different, the new ones have an outside slave tube, but all replacement options showed this as far as I could note, unless purchased used.
Q: hose closest to the machine side, with slave tube, does it connect to the same valve T as the left, both slave tube connection points come from the same valve point under the hood area
Or
Opposite, slave tube to opposing sides non slave tube connection?
Thanks
Or
Thanks
