when i used to run my 46a land clearing in the winter i made up an exhaust blower that would clamp on the end of my truck tailpipe (gas engine) and a long flexible metal hose with a wand/handle on the end. it had a flattish nozzle on the end. idle up the truck engine and it would develop sufficient pressure to blow a lot of dry leaf and bark debris out of the rad. i only used it after having the fan blowing and only if turning the fan blades did not get it clean enough. i used to turn the fan blades at least once a day and only occasionally used the exhaust blower. by watching the temp gauge and water pressure i could tell when the rad was getting plugged, then i would turn the fan blades to push, work it for 1/2 hr, freeze to death, then turn them back to pull and be toasty warm again
. the best temp in my opinion, for land clearing, is -20c or colder because all the small trees and brush shears off better and less dirt in the piles
