justsomedude
Hello everybody.
Hopefully someone here can give me a little guidance.
Cat 420eit
SN Dan00662
Problem: stabilizer auto up function not working correctly. Cylinder will move when activated by the control but the magnetic detent on one of the controls does not hold the control in place. I have put a screwdriver against the magnet and it does energize and become magnetic but when using the control the magnet feels really weak and does not stick. I have swapped the power wires for the other detent next to it which is working properly but it didn't seem to make a difference. That leads me to suspect the coil is bad / underpowered or something in the actual valve is pushing back hard enough to keep it from holding. Do these coils get weak over time or could there be another factor here? I'm unable to find a part number for this coil in the parts manual. I'm seeing a similar situation with the detent for the float function but not sure if its related. Any one had any experience with this? Is there somewhere else i should check?
Cat 420eit
SN Dan00662
