contractor was using our Komatsu WB-140-2N backhoe to move some stuff on our remodel, I wasn’t paying attention to how much he was using the machine, unfortunately a leak at the rear main seal got worse (I saw the trail it left) and it ran out of oil & the engine seized. Not in a good place to work on, on the wrong side of a big trench, outriggers out, bucket down, boom out.
So we removed the front drive shaft and dropped the pan, a shard of aluminum in the oil gave a clue as to what was in store. The rear main bearing has spun, carving a groove in the cap and saddle in the block and the crank has a crack starting to form. Had a set of main & rod bearings which we installed, hope to get it running to the point where we can baby it and get it out of the muddy field it is in and into the shop.
So what to do? It’s a Yanmar S4D106, which is fairly common. Found a number of cranks on eBay, so it’s just a matter of which one. Bigger problem is the block, is it a lost cause? I have read of a number of cases where folks have used JB weld on main bearings with some success. Is this just a bad idea - not sure what I have to loose. This is a farm machine, gets used a few hours a month - but really miss it now it’s down.
