Chewie2105
hey everyone running into some issues and wanted to quiz the collective. have a couple genie 34/22 booms at work that need to split and replace the main rotate bearing assembly (excessive play)
tentative plan is to unbolt, jack up the house and support it with steel saw horses (2x2 square tube .188 wall) and then slide 2 I beams under the unit to support the house while pulling the carbody out and replacing the bearing
my issue is in sizing the I beam I need, roughly looking at a 10 ft span, 2 beams ideally though a third is not out of the question.
don't want to lift higher then I need to but need to ensure safety
machine total weighs 10000lbs, budgeting house weighing 7000-8000 to give some space
any help would be appreciated
