imjustdave
Unfortunately I'm a very data driven type and look at numbers a bit too much I have to admit.
I'm looking to get another Mini Ex 50 - 55 size and looking at the spec sheets, does anyone feel like specs are all over the place? In comparing breakout force, I can't believe they are measuring the same way, a lot of specs are very similar but breakout seems excessive. I can't see how 1 machine has hundreds sometimes 1500 - 2k more when most machine from multiple brands are very similar in dimensions ETC.
Here is a good Example I found between Cat and Yanmar
Example
Vio55
11,850lb machine, 47HP
Max digging force 9,419lbs
Cat 305CR
11,016lb 45 ISO HP and 48 SAE HP
Digging Force 11,061 lbf
1,642 lbs difference? Can this be right? My thoughts are your pulling on a stump and 1k+ lbs is significant. If I put a force scale on a tooth would I really see the differance?
Example
Vio55
Cat 305CR
