So i am still having problems with this machine. I have put it on the back burner since last winter and it is still driving me crazy. I started a thread a while ago called Cummins injection pump help.
To start from the beginning, i was pulling this machine around the shop to get it ready for a job. I pulled it up to the door shut it off and went in to get some tools. When i came back out i re-started the machine, lowered the jack and extended the axles. I was going to adjust the swing control and tried to run the functions and everything that runs the boom was dead. The EMS system was tripping and locking everything out. I tried to look everything over for obvious problems and couldnt find any. I called Snorkel a couple of days later and the tech walked me through a few things to try which i did with no success. It always seemed to me that there was a weak ground wire or a drop in voltage somewhere i couldnt find.
Anyway i went to work on it again a few weeks later and the machine wouldnt start (which was never an issue). After going through everything i knew to do i called a mechanic. The mechanic and the people who replied to my cummins thread said the injection pump needed rebuilt. I had that done and replaced it and still nothing. So that brings us to present and i still have no idea what to do. I dont want to load this thing up and take it to a shop (which is my only option given the companies around here who know this machine) and spend 20,000 to find out. I have a little time to work on this and i have no idea where to start.
Things i have tried: Blew all lines out from injection pump to tank, cleaned tank and replaced fuel, replaced batteries, replaced fuel filter, blew out injection lines, replaced some fuel lines, ran a jumper wire to the injection pump
Questions: Does the computer or EMS system have something to do with this not starting? I have tried to run a jumper wire to the fuel shut off solenoid. How likely is it that the injectors are bad? The machine cranks a little hard and slow even with new batteries, what causes this?
I am totally stumped so i am willing to try about anything........ Thank you!!
