Shimmy1
2006 Freightliner Colombia with C13. I forgot to get the VIN, but we believe it has a Eaton AutoShift with the centrifugal type clutch. It has been growling when engaging for a while, but once you're moving works fine.
Today, driver called. Said truck wouldn't go into gear. Shut truck off for a few minutes, started, went into gear, drove back to shop. Tried to drive into shop, would not go into gear even after shutting off. Pulled in, let sit for hour. No trans light, when it won't go into gear the display just blinks the down arrow and 1, like it does when it works. Also, there is a slight humming or whining noise when it won't go into gear. Apologies that I don't have much more at this time.
Transmission looks like this.
