Some funny things can happen to crawlers when you get them on an extreme side-slope. First is weight transfer onto the downhill track. You think the uphill track is planted and carrying weight, then you try to steer and find you can't as the uphill track isn't carrying much at all. Then you start to drift downhill and unless you've got a substantial windrow below you, you can't do anything about it. Then when you get near the limit, even with a correctly adjusted, or even slightly too-tight track, you find the idler trying to walk out of the track chain, and you end up with the chain jammed between the idler and chassis and no way of driving down off the slope. And if you overfill the sump to compensate, you're okay until the oil can't drain out of the turbo due to the angle, and if you don't overfill the sump you starve the pump. However, unless you're very unlucky, none of this will happen on a 2:1 with good material under you.
