RayfromTX
Thanks Don-
I joined on the allischalmers site but a search didn't turn up anything useful. I will post there later. It turns out our machine is a Fiat-Allis 65 which according to your research puts it between a '75 and a '79. It runs great, starts right up, charges the battery, is pretty tight and quiet and smooth. It runs at an acceptable speed in 1st gear but we would really benefit from getting low range back. Tires, hydraulics and blade are all in decent shape.
We are thinking to continue to look for the top shaft gear or failing that, we have found the same gear in a shorter cluster that we may be able to cut off that cluster and weld to our cluster. Is it possible to build a tooth back on to a broken gear? That sounds sketchy at best but I am not a machinist.
