Shims/spacers to make another bucket fit my 410?
Jim weslock
Ontario
Hi Friends,
My original jd410 bucket is now cracked and needs replacing. I have an acceptable one but it requires spacers on the pins to fill the space. What do most people do in this case? I need 4-1” bushings, 2 on the top and 2 on the bottom pins. A friend suggested some heavy duty piping the correct size ID. Is that a good idea and if yes, what grade pipe would you use?
Jonas302
mn
We used to make some for the excavator out of pipe or more correctly dom tubing but we had a piece with about 2 inch thick walls it worked great for spacers
You can torch cut them out of plate most big metal supply places can set that up on the cutting table and make them for you now problem
I have always used mild steel although alloy would be ok the cost would not be worth it
What size are your pins?
cosmaar1
Ohio
For my 555e bucket I use 1 1/2” washers for the extra space. Probably have 10 or so smacking around.
