SEVCON MillipaK workflow
Postal2
Saint-Petersburg
MCU is MC908MR32CFUE. Will be continued...
Postal2
Saint-Petersburg
I didn't clean the compound, but I can see how it was done. The body is sawn along the perimeter, the compound is mechanically picked out, then the body is glued with "Poxipol" glue. I will take additional photos of the sawing.
Postal2
Saint-Petersburg
Sawing of the MillipaK.
Postal2
Saint-Petersburg
Unable to read security data from Motorola (photo), unable to read its firmware. Only backup copy AT25020B (attached).
  • backup_AT25020B.zip
Postal2
Saint-Petersburg
MCU reading successful.
[Command: Read MCU Security Bytes]
Start hardware...<XPROG-box>...OK.
Check authorization...OK.
Read device configuration...OK.
Configure hardware...OK.
Bypass Security...Security bytes 0xECA3ECA3ECA3ECA3 ...OK.
Elapsed time: 00:00:13.656
Archive contains 32 kilobytes starting from offset 0x8000.
  • hc908mr32.zip
Postal2
Saint-Petersburg
Photo of the tracks under the processor in case you damage them when removing them. The processor is firmly glued, difficult to remove.
Postal2
Saint-Petersburg
MC908MR32 programmed successfully (screenshot). Real COM-uart on MAX3232 chip is needed, usb-uart adapters do not work. Prepared file in s19 format is attached.
  • hc908mr_s19.zip
