At some point this summer I am going to set up my international to pull the trailer. It has no air or electric currently at the end of the frame. How do you go about running the air lines? I. Also want to set it up with electric brakes. The truck is a 94 so no abs or computer bs to deal with.
Thanks!
as far as running air to the rear, seems like States vary on their application/requirements. In NC, you must have a brake valve/button on the dash. If your state isnt like mine. you can tee, into the main brake air lines and run to the rear. You either need to install shutoff valves at the hitch, or use hydraulic push and lock couplings. Its kinda pricey to install a dash brake value.
Electrical is kinda straight forward, install a electrical receptacle, to match your trailers plug. It is confusing if you dont have a test light and wiring order.
Electric brakes, all controllers has wiring diagrams supplied, power, ground, feed from brake light switch and wiring to rear receptacle pretty simple also if you have a test light and a little electrical knowledge. Make sure you buy a controller that is strong enough, to handle your trailer, A good one cost about $100-$150
Good Luck
