You'd sure need a whole lot more front suspension. I've read the weight, I can't remember, but it is a lot!I worked on and ran several that were in tractors back then i saw 2 pickups that had them. I wanted one bad for a one ton i had but never got one.
I had it planned to use a 1 1/2 ton front axle and drill it for ton wheels. I saw in a magizine in the early 80s a guy bought a brand new Blazer 2WD he lenghtened it made a 6x6 with a 3208 but the real crasy part was he used a Firestone/ford f150 front axle.You'd sure need a whole lot more front suspension. I've read the weight, I can't remember, but it is a lot!
I’ve re-powered boats with 3208’s after removing Detroits 8.2’s. Maybe not the best option but lots of times nothing else will fit except another short v8.
I think the 3208 makes for a decent seine boat engine. I’ve worked on them after recover from Davy Jones locker. Flush the crank case with diesel a couple times, add clean lube & filters, prime the fuel system and back to fishing.
Yes I used to own a 6.9 IH in a F250 Ford . I had to use starting fluid in the summer to start it . I now own a deleted powerstroke Ford that smokes like a heathen and the smell of raw diesel is just everywhere especially in colder temps . As for the 3208 yes she has her own distinctive smell too . Enjoy the day guys and gals ....Valentine’s DayAll these lame engines from that era had their own unique smell. I'm thinking of the 3208, 8.2, 6.9 IH, 9.0 IH. You get a bunch of them congregated in one area on a cold morning, it made you question your decisions in life.
That story there just goes to prove that the dirty old 3208 was a pretty decent workhorse in its dayApparently back in the 70s there were lots of 3208-powered gensets on platforms in the North Sea offshore oil industry. The story was that when a genset wore out a welder would be called to cut round the floor under the set and drop the whole shooting match into the sea. Weld a plate over the hole, install a brand-new set, and happy daze - until the next time.
