I'm documenting all the models you listed. The larger machines in the 52K pound range like Mr. Honky Cat mentioned seems to be less expensive than the smaller models.
Yes Anthony I drug some savings out of the ground and have less than $30,000 in it and it was bought at auction from a 1- owner that was an electrician and all he did with it was dig right of way ditches for his buried electric cable. Low hours, clean as a whistle and had it shipped to Oklahoma from Wisconsin. Probably the best find ever for a heavy duty machine in my small arsenal. Now I have added a 2004 Peterbilt extended hood 280 in wheelbase with a C-15 550 hp Caterpillar Day Cab that was overhauled fresh, and I bought it in Victoria Texas and drove it back to Oklahoma and put the first miles on the engine on the way home. Then I found a Fontaine 55 Ton detachable RGN in Ohio and went picked it up to haul my gear on because there is a big need for people that want to work m, plucking these invasive cedars from peoples large Ranches and Farms. The cedars are worse than the Wild Boar invasion. They have quietly taken over massive properties. I am working with my 19 year old son at getting ready to go help other people that seek our skills eliminating cedar trees. You can do the same thing in Texas. It’s addicting! Just be sure you are patient and don’t jump at the first machine you choose because there are 1,000’s of older machines out there that need a job. Maintain and grease your excavator, tractor, dozer, or track loader every day and change oil and filters regularly and you will be surprised at how well they (machines) work for you. If I can help in any way pm me. I don’t know much, but I know cedars and learn something new every day. The day I stop learning is the day I’m done.From what Ive seen the larger machines in the 50k lb range are less expensive than the midsize units. I assume thats because they are harder to move.
Happy Clearing!
Good Luck!
Honky Cat
