Doug Overkill
My rebuild project came to a screeching halt this weekend. I was cleaning up my work area where my engine rebuild was progressing smoothly. I had the head back on on and the timing gear cover and water pump all buttoned up. I thought my next task was to cold set valve backlash and then mount it in the tractor.
Then I found the oil slinger sitting next to the fuel pump on the bench. I have been diligently following the manual every step of the way. I have now read the assembly of the crank section more than 5 times. (twice before, once during and again after). There is NO MENTION of the damn oil slinger. Yes it is in the parts diagram but not at all in the step by step. Every other piece but not this one.
I am so pissed!
Now I have destroyed 2 gaskets getting back to where I was 4 days ago. Except then I had all the parts and gaskets I needed.
I have been so careful following all the steps because I can't afford to go backwards. Either time or money. But this seems like a real miss in the manual.
Have any of you been sabotaged by the manual?
I am so pissed!
