Scrap axles
cfherrman
Hays, Kansas
I might be buying a set of tandems that are like my rig, it's on a old truck that will be cut up for scrap, trying to figure out a price how much would you get for a set at a scrap yard? I might get the twin steer front too
IceHole
AK
Here, id be happy if they didn't charge me to take them for scrap!
Average weight front drive with axles, drums and brake hardware--For a SQ series 1,350,
rear 1,225 lbs--- with suspension figure the whole mess at 4,000.
Most used cut offs are around $2,000- 2,500.
Depends on several things--model, suspension, ratio, and now days type of brakes, a useable
wanted set goes for $3,500 and up out here. Old junk won't even bring scrap price. A set of
SQHD's doesn't matter ratio, maybe-a big maybe $ 1,000 for both.
cfherrman
Hays, Kansas
I sold old set of Rockwell's for $1000, and they could be made into a good set.
This set might be able to be used and they look newer than mine, but they are still old. Hopefully they are close to the right ratio for a top speed in the 40's
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I'd like to have a rear unimount hub and single piece drive axle for it. No need for anything else.
IceHole
AK
I threw out a center section with power divider that had an oil filter on it? Anyone ever see that before? Was under a cover, looked like a regular spin on oil filter.
cfherrman
Hays, Kansas
Here's a really bad screen shot of the rears
If you notice, everything is junk
