Samsung SL 120 only shifts into 1 and 2
mattyt1984
New York
The display lights up to F1 F2 F3 F4 but it only feels like ti goes into 2nd and no higher. Also on the right side where all the switches are what are the 2 lower right rocker switches? The one on the lower right has to be switched or I only get neutral? What is the swith and why does this only shift from 1 to 2 gear?
Bigbert
Germany
Consulting Engineer
The transmission is a ZF 4WG150? With TCU EST17T or 25?
Guess, output speed sensor is broken or cable somewhere interrupted.
mattyt1984
New York
It is on solid. I did drive it today and it does shift from 2 to 3 I am not sure if it is shifting from 3 to 4 though, The engine revs up all the ways but it does not seem like it has a lot of power. I checked trans oil and level is way over filled. Pic below shows my dash what are the red2 buttons on bottom right?
Bigbert
Germany
Consulting Engineer
Hello mattyt
This is Photo taken out of a book Samsung Wheel loader training course. Possibly it gets you some indication.
Good luck
Bigbert
Germany
Consulting Engineer
...and, if it is a ZF 4WG xxx:
Oil level at 70 degrees C (warm), engine at low idle, tranny neutral aound 50 mm below center output shaft.
Too high oil level will cut drive performance dramatically esp. at higher speed.
  • Like
Reactions: DB2
mattyt1984
New York
I am thinking it is speed sensor as the speedometer does not work either, But how does it shift from 1st to 2nd. Does anyone have the speed sensor part number and location?
Bigbert
Germany
Consulting Engineer
See here a picture of a typical ZF speed sensor for WG 120/150/180/200.
I'm not sure whether length (and number) is correct for your specific transmission.
Pic at bottom is a typical location of output speed sensor.
coty_v
florida
hi all, ive got a 120-2 that will not engage either F or R in any gear it will only flash D5 which im assuming is a code. the loader just had a reman engine put in by another shop and customer test drove it, loaded it on the trailer and backed it off at their shop, shortly after they tried to run it and nothing. ive gone through the shifter and its all showing power, the trans is reading at 233 psi, the speed sensor is fine, and all fuses behind the seat are good. ive searched the web and theres not much for these, any help would be appreciated
ClaytB
Maine
I also have a SL120-2 Samsung loader that only has 1st and 2nd gear. Have had it looked at by a couple of guys last one was local Volvo dealer ,so far i have had shifter rebuilt and changed relay behind seat then he found broken speed sensor by output shaft on transmission, I told him to change it but after a few weeks of supposedly trying to find one they gave up told me to come get it and go with it as is. Where can i get this sensor? currently held in place with a couple wire ties. I believe the part # is 8320-14070?
