yep - had one last week
Had a hose blow off on my t190... enough oil went directly into the rubber air scoop, that it hydrolocked a cylinder and bent a rod...can not believe enough oil went thru the filters and turbo that could do this... but it did... consider you lucky if you only ended up with a dirty engine... my unit had only 500 hours on it...i contacted Bobcat and they said there were no issues with that type of connection...I have 4 Bobcats and this is a first for me... I am going to put a hose with two clamps on the outside of this connection, just it case it happens again...pulling the engine and changing a rod on a new unit just because of a design flaw, is not much fun...it would be interesting to see if others had also had this problem, cause i noticed that your post is a few months old with no replies
