S175 no heat/blower motor
Erockk
Ny
Fan motor is not blowing
Has power at top left relay (hvac)
Has power at fuse to the left(hvac)
has no power at b terminal motor speed switch
i replaced motor switch (might be a coincident) but then fan blower worked
i moved the machine around and when i went to try switch again it didnt work
Need help where to check next
frg
tehran
check the connectivity between hvac relay pin 87 ,and B terminal on blower switch.
Erockk
Ny
check continuity between relay and b terminal and all checked out ok. It almost seems like the relay isnt activating. Ive switched relays around but still same thing. Is there anyway to bypass relay? Im assuming could jump pins 30 and 87? But other then that i dont know where to look?
Erockk
Ny
Also not getting power to bottom right 2 fuses, looks like say power plug and something unswitched
frg
tehran
HVAC relay, powered by SWITCH POWER relay. as soon as you power up the machin, the switch power relay energized and send voltage to Hvac relay. check the connection between switch power relay and hvac relay. also check the negative(-) terminal on hvac relay.
you can bypass this relay by connectin pin 30 to 87. but it drown you battery.
Erockk
Ny
Ive been looking at wiring diagrams and i came to that conclusion too. I checked continuity between pin 87 on switch relay and 86 on hvac I got nothing. Ive noticed wiper switch has no power too, assuming it is coming from same source the switch power relay. Assuming pin 87 loose in fuse panel. Will check that out tomorrow
Coaldust
North of the 60
Winter is coming!. Gotta get that heater working, post haste. BTW, that’s some solid troubleshooting. Keep up the good work.
  • Like
Reactions: DB2
Erockk
Ny
woke up this morning to a dome light on and heat and wipers working. Cant make this up. But then again did clean all engine grounds and push the back of the fuse box boot to try and trace a 21-03 which just pop up yesterday for glow plugs. These electrical problems are a pain. Going to have to pull that fuse boot again and cause another random problem. Atleast can put interior back together knowing isnt a problem from above headliner
Erockk
Ny
21-03 turned out to be a bad relay from me switching them around. Found out 3 relays are bad. Thanks all for help looks like ive figured out the bad electrical on this neglected machine for now
