Pull the relay and check it. Then use your meter to see if the voltage is going through the system to the relay. That would test the start circuit from key switch to relay. If not test that your getting power out of the module to key switch when on. Twist it over to start and see if your getting start signal from key switch to ignition plug there on the module. If you have power in and start signal out from your switch to the 3 wire switch plug on the module. If you do then you need to go to the module plug and make sure that start signal out of the module is there. If its all good at the switch to the switch plug on module and your not getting it out of the module then its probably the module
Just FYI. There is an updated switch kit for that machine, like you mentioned. Your switch is probably bad. I’ve replaced 6 or seven of those to the new style because of low-hour failures.
Hello Dualtrade,
Interesting scenario you have going there. Since you are handy with a scope, check the 12+ input on that module. I’m curious if the data bus is slow because the 12+ input is sketchy. Check the ground, too. If the power and ground are good, I’d be tempted to replace the module.
Any codes?
