I see one of Arcata Redwood's big Madill swingers has made it's way to Ramsey's in Chehalis.
If you get tired of the 009 with just a couple of drums why not change it out with an 044 and get a six drums allright? Old 044 tag, no serial, mounted on 065 rubber tired carrier. Oregon.
WHY???? What an abortion! LOL!
wonder how they got her to travel?? hopefully not like the rest of the rubber 044s. would be a very short down drive shaft,tight squeeze for an angle drive box!..... gives me pat carson bulldozing flashbacks, cypre river .
Hi Torkel. When I was doing 009 final assembly we welded a small 3/4 or1"x3"pc of FB with s/n stamped in it to the front left corner of the machine on the channel that the front saddle sat on. This was mainly just a reference number as we mostly had 3 or 4 machines being assembled at the same time and our hours had to be charged against the proper machine. Parts also. As I recall there was also a small s/n plate on the carrier put on by the supplier of the carrier. On the winch there was a s/n plate on the main frame below the main drum. The spec plate and maybe another s/n plate were on the valve bank mounting frame and I think there was a plate on the side of the a-frame near the valve bank. There was also a small stamped plate like the one on the front of the machine put on the bottom of the spar by the guys that built them again mainly to keep the time booked properly as they went through the system including the paint shop. The official s/n plates didn't go on until the final QC checks were done and it was possible but very unlikly a machine would have a different s/n than it was built under. 044 144 had a s/n welded on the tot of the carrier deck and onto the crossdrive housing as each housing was fitted and drilled to match a specific hull. The housing was then sent to another dept for assembly. Again we might be building 3 or 4 machines at the same time and each crossdrive had to go back on the right carrier when it came back for final assembly Also a matter of booking the hours to the right machine. I think we also used to put a little plate on the back corner of the hull. 071s had them on the on the angle iron that the decking sat in at the front of the machine. RT carriers had them on the front of the carrier. Again all these little plates were just for reference in the shop for time and parts charges. Don't know where or if the later machines were marked during building as I moved out of assembly and into field service. d.d.donkey doc and donkeydoctor: Do you know if Madill welded the serial numbers on at some special spots on their machines? Many carriers have a small plate in front, some 044/144 carriers have it welded on, but what about winches and towers? This would be very nice to know since I many times have tried to recognize machines lacking the build plate.
