furpo
12002 getting a bit of love
Here is the 120 with both gears off the main drum. The preload had come off the gear idler bearings so before it became an issue we sorted it. The shaft bearing also were not retained properly allowing some end float in the whole assembly. Sorted now as well.
Just a tip for anyone pulling the rear main slip clutch out of one of these. If you remove the cage from the Witchita you can get the clutch past the strawline drum without pulling the strawline drum. To get the cage off you have to undo the cap bolts from behind the clutch assembly.
