I’m helping out at the farm and there’s a rusty S650 that used to be used for snow removal. There’s more rust than white paint. I’m a mechanic but I know nothing about these machines. It has the operators manual behind the seat, found the fuse box, all of the fuses were good. The main relay box fuses were covered in dielectric grease, probably a hint this has had problems before.
The left side doesn’t turn on at all, gauges, lights, switches, or climate control. The right screen turns on with the bobcat logo and fades all white. Cranks and starts good, runs for a few seconds and shuts off.
I checked the battery grounds…rust. Cleaned everything back there. Then it wouldn’t do anything at all. How does cleaning grounds make it worse? Then I cleaned the positive post and the 100A master fuse, also rust. Back to square one, runs and shuts off, no left side electrical, screen turns all white.
How do I get behind the fuse box? I’m thinking the power wires in the are corroded behind it. Is there any chassis grounds in the cab area? These bobcats don’t look mechanic friendly to get to things. Thanks in advance!
